JUNO-STAGE
Eπιτέλους ένας άξιος διάδοχος του Juno 106 φαίνεται να είναι το Juno Stage.
specs:
Keyboard
    76 keys (with velocity)
Sound Generator
Maximum Polyphony
    128 voices
Parts
    16 parts
Wave Memory
    128MB (16-bit linear equivalent)
Preset Memory
    Patches: 1027 + 256 (GM2), Rhythm Sets: 32 + 9 (GM2), Performances: 64
User Memory
    Patches: 256, Rhythm Sets: 32, Performances: 64
Effects
    MFX: 3 systems, 79 types, Chorus: 3 types, Reverb: 5 types, Mic Input, Reverb: 8 types
Song Player
File Format
    SMF: format-0/1, Audio File: WAV/AIFF/MP3
Other
Arpeggiator
    Preset: 128, User: 128
Rhythm Pattern
    Preset: 256 (26 groups), User: 256 (32 groups)
Chord Memory
    Preset: 64, User: 64
Controllers
    D BEAM Controller, Pitch Bend/Modulation Lever, S1/S2 Switches, Sound Modify Knob x 7
Display
    240 x 64 dots graphic LCD (with backlit)
Expansion Slots
    SRX expansion board: 2 slot
External Storage Device
    USB MEMORY (supports USB 2.0 Hi-Speed Flash Memory)
Connectors
    Headphone Jack, Song/Click Out Jack, Output Jacks (L (MONO), R): 1/4 inch phone type, Mic Input Jack: 1/4 inch phone type or XLR type (phantom power), MIDI Connectors (IN, OUT), Hold Pedal Jack, Control Pedal Jack, Patch Select Jack, USB Connector (MIDI)
Power Supply
    DC 9 V (AC Adaptor)
Current draw
    2,000 mA
Accessories
    Owner's Manual, CD-ROM x 2 (Editor/Librarian/USB MIDI driver, SONAR LE), Music Player Pad, Music Player Cable, USB Memory Protector, AC Adaptor
Options
    Wave Expansion Board: SRX Series, Keyboard Stand: KS-12, Pedal Switch: DP series, Foot Switch: BOSS FS-5U/FS-6, Expression Pedal: EV-5, Connection Cord: PCS-31, USB Memory: M-UF1G
http://www.rolandus.com/products/productdetails.aspx?ObjectId=967&ParentId=72
Dance music will never die!!!!!!!
Το 106 είναι αναλογικό. Αυτο μάλλον είναι ενα μεγαλυτερο Juno-g.
Βαριέμαι να συγκρίνω τα specs των 2 για να το επιβεβαιωσω, αλα σίγουρα έχει πιο πολλά πληκτρα και 2 srx slots.
Kαι το SH-101 αναλογικό είναι αλλά το 201 που βγήκε σαν αντικαταστάτης του 101 είναι v.a.Tι να κάνουμε τώρα ????Αυτό το αποφασίζει η Roland.To ίδιο έγινε και με το juno G που η Roland το παρουσιάζει σαν αντικαταστάτη του 106 απλώς με το νέο G θέλει να το φέρει ποιο κοντά με το 106 και ποιο αναβαθμισμένο σε σχέση με το G.Έλεος[/img].Εξάλλου από το 1990 και μετά  είδες κανένα true analog από τη Roland?
Βρε τίποτα να μην κανουμε, δε θα χασω και τον ύπνο μου :) . Απλα είναι αστείο να το χαρακτηρίζουν διαδοχο, αντικαταστατη κτλ. Και βεβαια, αλλο analog και v.a. και άλλο analog και rompler.
(η roland ολο βλακειες αποφασίζει :p)*
*δεν είναι καταγγελία, απλα είνα μια αστεία φραση, χρησιμοποιω πολλα ρολανδ προιοντα
Καλά συμφωνώ ότι δεν θα χαλάσουμε και τον ύπνο μας ;).Πάντως είναι μια καλή λύση (σε σχέση δυνατοτήτων) με το  παλιό G ή το 106.Τλσπ ας ελπίσουμε ότι κάποια στιγμή θα βγάλουν και κάτι καλό και αξιόλογο όπως έγινε με το v-synth,jp-8080,jd-800,Juno 1-2,D50 k.α. που πραγματικά μας έκαναν να μην κοιμηθούμε ;).
Αυτό που σίγουρα κατάλαβα είναι ότι το stage έχει και vocoder. Κατά τα άλλα πάνω κάτω ίδιο δεν είναι κάπως με το juno-g? Και το Interface τους είναι όμοιο. Το stage είναι και πιο χοντρό κιόλας, 4 ολόκληρα κιλά!  :P
www.travelforum.gr
Φαίνεται να είναι ενα πολυ καλο performance οργανο για live και αυτο με κερδίζει. Βεβαια αυτο που με ξενερωνε μεχρι τώρα ήταν τα αθλια hammond (εγω τα θελω πολυ .....χμμ....πως να το πω....screamy :p και γεματα). Απο τα πρωτα fantom μεχρι το fantom-x και τα juno κτλ, ήταν λογος για να κοιταω korg (μουφα παλι, αλλα στη μιξη του live πειθουν περισσότερο).
Και αν είναι να παμε σε srx κλάφτα.
Τελοσπαντων φαίνεται καλή λύση all around για live, ειδικα αν εχουν κρατησει το χαμηλό βαρος του juno-g και εχουν στρωσει και λίγο τα χαμοντακια :) θα το κοιταξω
To V-synth μου τρωει τον υπνο 1 χρονο τωρα. ;)
