DaveMurrayJr Δημοσιευμένο 24 Ιανουαρίου 2008 Share Δημοσιευμένο 24 Ιανουαρίου 2008 Τωρα τελευταια, σκεφτομαι να αγορασω καποια καλυτερη καρτα ηχου απο την onboard. Καθως προοριζεται για recording κιθαρας, καμιας φωνης αμα λαχει (και κανα midi keyboard στο μελλον πιθανως), σκεφτηκα την προαναφερθεισα. Τι αποψη εχουν οι ψαγμενοι και δοκιμασμενοι??? Εδω ειναι τα χαρακτιριστηκα της οπως αναφερονται στο site της Creative... Technical Specifications • 24-bit Analog-to-Digital conversion of analog inputs at 96kHz sample rate • 24-bit Digital-to-Analog conversion of digital sources at 96kHz to analog 7.1 speaker output • 24-bit Digital-to-Analog conversion of stereo digital sources at 192kHz to stereo output • 16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz • ASIO 2.0 16-bit and 24-bit support at 44.1kHz, 48kHz and 96kHz with direct monitoring • Enhanced SoundFont support of up to 24-bit resolution • 64MB of X-RAM Audio Performance (Rated Output @ 2Vrms, Typical Value) • Signal-to-Noise Ratio (20kHz Low-pass filter, A-Weighted) Stereo Output 116dB Front and Rear Channels 116dB Center, Subwoofer and Side Channels 116dB • Total Harmonic Distortion + Noise at 1kHz (20kHz Low-pass filter) = 0.008% • Frequency Response (+/-3dB, 24-bit/96kHz input) = <10Hz to 46kHz • Frequency Response (+/-3dB, 24-bit/192kHz input) = <10Hz to 88kHz (Stereo only) Connectivity • FlexiJack (3-in-1 function, Digital In / Line In / Microphone) via 3.50mm mini jack • Line level out (Front / Rear / Center / Subwoofer / Rear Center) via 3.50mm mini jacks • AUX_IN line-level analog input via 4-pin Molex connector on card • One AD_Link (26 pin) connector for linking to the X-Fi I/O Console I/O Drive Connectivity • Two RCA jacks for coaxial SPDIF input and output • Shared Auxiliary input/Phono input via RCA stereo jacks • Two optical connectors for optical SPDIF input and output • Two standard MIDI female connectors for MIDI input and output • Headphone output and volume control via 6.35 mm (1/4-inch) stereo jack • Shared line-level analog Line/Microphone input via 6.35 mm (1/4-inch) stereo jack. • Shared line-level analog Line/Hi-Z input via 6.35 mm (1/4-inch) stereo jack • DIN jack to connect Creative analog speaker systems with the wired remote control or Audio Control Pod that comes with the speakers • One AD_LINK connector for linking to the audio card What frequency are YOU getting? Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
tugito Δημοσιευμένο 24 Ιανουαρίου 2008 Share Δημοσιευμένο 24 Ιανουαρίου 2008 Θανατος στις soundblaster, δεν εχει νοημα με τετοιες τιμές. Παρε κάποια καλούλα maudio ή edirol UA-25 ή tascam ή πάει λέγοντας... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
boukas Δημοσιευμένο 25 Ιανουαρίου 2008 Share Δημοσιευμένο 25 Ιανουαρίου 2008 Εκτός από αυτό, αφού θες να γράφεις και κιθάρα, έχει την ειδική είσοδο γιαυτήν; Όχι. Άρα; Δεν σου κάνει. Χώρια που και η υποδοχή για μικρόφωνο είναι η απλή (3.5mm? Δεν έχεις walkman) και πάλι δε σου κάνει. "Όχι άλλες TELE" Τάδε έφη Boukaw7 Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
DaveMurrayJr Δημοσιευμένο 25 Ιανουαρίου 2008 OP Share Δημοσιευμένο 25 Ιανουαρίου 2008 σωστα αφτα που λετε, αλλα το πανελ το εξωτερικο, εχει καρφια μεγαλα και για mic και για κιθαρα... και εχει και midi, γι'αυτο τη σκεφτομαι... What frequency are YOU getting? Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
Metal_Tiger Δημοσιευμένο 25 Ιανουαρίου 2008 Share Δημοσιευμένο 25 Ιανουαρίου 2008 Εγω πηρα την alesis io 14 firewire και τα λογια ειναι περιτα... Κι ολα αυτα με 178Ε η καπου τοσο δε θυμαμαι ακριβως... Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
boukas Δημοσιευμένο 25 Ιανουαρίου 2008 Share Δημοσιευμένο 25 Ιανουαρίου 2008 σωστα αφτα που λετε, αλλα το πανελ το εξωτερικο, εχει καρφια μεγαλα και για mic και για κιθαρα... και εχει και midi, γι'αυτο τη σκεφτομαι... Βρες μου την είσοδο για κιθάρα και το μικ (με xlr εννοείται, για να βάλεις και κανά πυκνωτικό. Το ότι είναι μεγάλα και χωράει το καρφί της κιθάρας, δεν λέει τίποτα. Και άσε το εξωτερικό πανελ Βλέπεις τις 2 εισόδους αυτηνής; Τέτοια είσοδο θες. Και τα σωστά "καρφιά" για μικρόφωνο έχει και τις ειδικές εισόδους για κιθάρα το hiz που λέει (άλλοτε θα το δεις και ως instument). Εξάλλου η κάρτα σαν input γράφει: FlexiJack (3-in-1 function, Digital In / Line In / Microphone) via 3.50mm mini jack. Είναι άλλο το Line in και άλλο η είσοδος της κιθάρας. "Όχι άλλες TELE" Τάδε έφη Boukaw7 Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
starscream Δημοσιευμένο 25 Ιανουαρίου 2008 Share Δημοσιευμένο 25 Ιανουαρίου 2008 I/O Drive Connectivity • Two RCA jacks for coaxial SPDIF input and output • Shared Auxiliary input/Phono input via RCA stereo jacks • Two optical connectors for optical SPDIF input and output • Two standard MIDI female connectors for MIDI input and output • Headphone output and volume control via 6.35 mm (1/4-inch) stereo jack • Shared line-level analog Line/Microphone input via 6.35 mm (1/4-inch) stereo jack. • Shared line-level analog Line/Hi-Z input via 6.35 mm (1/4-inch) stereo jack • DIN jack to connect Creative analog speaker systems with the wired remote control or Audio Control Pod that comes with the speakers • One AD_LINK connector for linking to the audio card Η δεύτερη και η τρίτη υποδοχή από αριστερά είναι για μικ και για κιθάρα. Μετατροπείς από jack σε xlr μπορείς να βρεις εύκολα, αλλά δεν έχει phantom power, οπότε για πυκνωτικό θα χρειαστείς κάποιο stand-alone προενισχυτή ή μια κονσόλα. Η κάρτα αυτή είναι ενδιαφέρουσα επιλογή έχοντας πολύ καλούς ad/da μετατροπείς (νομίζω τους ίδιους με τις e-mu σειράς m (1212m, 1616m)) και γενικότερα specs, υποστήριξη drivers, αλλά προορίζεται κυρίως για multimedia χρήση δλδ home theater και gaming. Ειδικά αυτά τα πολυδιαφημισμένα 64 mb x-ram δε χρειάζονται μάλλον πουθενά :P Anyway η κάρτα θα είναι παραπάνω από μια χαρά για ηχογραφήσεις, αλλά ως soundblaster κάρτα ήχου δεν είναι ο σκοπός για τον οποίο φτιάχτηκε. Αν σε ενδιαφέρουν και οι multimedia δυνατότητες της (αν έχεις τη δυνατότητα να τις αξιοποιήσεις - τι να το κάνεις το native THX support άμα οδηγείς 2 monitor ηχεία ή multimedia ηχειάκια; θέλεις ένα αξιοπρέπες σετ 5.1) τότε ναι, είναι πολύ καλή επιλογή. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
DaveMurrayJr Δημοσιευμένο 25 Ιανουαρίου 2008 OP Share Δημοσιευμένο 25 Ιανουαρίου 2008 Ωραια... Σοφα λογια... θα το ψαξω πιο πολυ και θα αποφασισω... η αληθεια ειναι οτι εχω καλα συστημα 5,1... θα το κοιταξω πιο ειδικα και θα αποφασισω... Thx παντως για τις αποψεις... What frequency are YOU getting? Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
boukas Δημοσιευμένο 25 Ιανουαρίου 2008 Share Δημοσιευμένο 25 Ιανουαρίου 2008 ΩΧ σωστό, δεν το είδα μέσα στο κατεβατό αυτό: • Shared line-level analog Line/Hi-Z input via 6.35 mm (1/4-inch) stereo jack Οπότε για κιθάρα κάνει μια χαρά. Για το μικρόφωνο και την ποιότητά του, ας έχω τις επιφυλάξεις μου. Αλλά δε νομίζω να μην σου κάνει τη δουλειά που θες, οπότε αν θες πάρτην "Όχι άλλες TELE" Τάδε έφη Boukaw7 Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
