Hear the instrument
Το πουλάω για οικονομικούς λόγους και θέλω να πάρω κάτι αλλο
Piano type
Upright
Young Chang
Acoustic Piano
Year of manufacture
1975
Manufacturer’s Country
South Korea
NOIZ638972
  • My country
  • Europe
  • Worldwide
  • Local pickup
  • Νεα Yamaha synths: MOXF6 & MOXF8 297 replies
    … waveforms. More than double what’s in the MOX series. * Two separate acoustic piano sample sets taken from a couple of Yamaha’s finest grands - 9’ CFIIIS and 7’ S6. * Optional flash memory expansion board can be easily …
  • Yamaha Montage synth 82 replies
    …the keyboard and is perfect for playing a variety of instruments from acoustic piano to electric piano, synth sounds, organ and more! Live Set Live Set lets you organize your Performances however you want without copying…
  • Korg Krome 61 replies
    …standouts that weren’t found in Korg instruments prior to the Kronos. Acoustic piano: “Krome Grand Piano” and a few variations form the star piano sound, which is derived from the “German” piano in the Kronos’ SGX-1 mode…
  • Αγορά synth για portable καταστάσεις-Novation Mininova 85 replies
    …ιμη δεν με ενδιαφερουν οι απειροι ηχοι απλα mellotron ,electric piano,acoustic piano,hammond organ να καλυπτω ηχους των early 70's και ειμαι κομπλε ;D ;) Και παλι ευχαριστω :D
  • Ποιό stage πιάνο; 61 replies
    …nce String Resonance is the acoustic phenomenon that occurs inside an acoustic piano or a grand piano when strings, or parts of strings, resonate at their fundamental or harmonic frequencies when other strings are played…
  • New Hammond XK-5 25 replies
    …ntial keyboard instruments in musical history, perhaps apart from the acoustic piano. When paired with the spinning Leslie speaker, the Hammond’s sonic versatility defined the electrified keyboard sound of genres from Ro…
  • Δείγματα πιάνου δωρεάν κανείς; 21 replies
    …ας λοιπόν στο γούγλη για δείγματα έπεσα επάνω σε αυτό το πιάνο mildon acoustic piano sfz.http://www.mildonstudios.com/static/acoustic_piano_sfz.html Ο ήχος του μου άρεσε έτσι το κατέβασα και ξεκίνησα επεξεργασία. Αν και …
  • midi keyboard 49keys 19 replies
    …et them apart. Stage pianos usually provide a small number of sounds (acoustic piano, electric piano, and Hammond organ) in a rugged case." (απορω γιατι καθομαι και γραφω, επρεπε απ'την αρχη να σε παραπεμψω στη φιλη μας …
