Πωλειται GOLD NOTE DS-10 USB DAC - STREAMER -PREAMPLIFIER.....εδω παραθετω τα χαρακτηριστικα του....TECHNICAL SPECIFICATIONS
MAIN FEATURES
D/A Converter native PCM up to 32bit/384kHz & DSD 64/128 native, via
DoP and PCM Streamer & Network Player PCM and DSD64
Frequency response: 20Hz-20kHz +/-0.1dB
THD – Total Harmonic Distortion: 0.001% max
Signal to Noise ratio: -125dB
Dynamic range: 120dB
Output impedance: 50ohm
Preamp Stage Volume Control: enabled/disabled by remote
POWER
Multiple Transformer proprietary power supply.
Power consumption: 30W - 230 V.DIGITAL INPUTS
1Ethernet LAN & Wi-Fi (DSD64 via PCM) Resolution: PCM up to 24bit/192kHz
1x RCA S/PDIF coaxial PCM asynchronous up to 24bit/192kHz
2x TOS-optical PCM asynchronous up to 24bit/192kHz
1x AES/EBU balanced PCM asynchronous up to 24bit/192kHz
1 x USB-B asynchronous native and DoP DSD64/128 and PCM up to 32bit/384kHz
1x USB-A port to feed USB flash memories and HDD, FAT32/NTFS formatted playing
DSD64 and PCM up to 24bit/192kHz
AUDIO OUTPUTS
Line
output level (fixed): stereo RCA @ 1Volt and balanced XLR @ 4Volt
CONNECTIVITY
LAN/WLAN
WiFi: 802.11b/g via RJ45 10/100Mbps socket and Antenna playing native and DoP
DSD64/128 and PCM up to 24bit/192kHz.Blueooth 5.0
Infrared remote: RC5 proprietary code
SUPPORTED AUDIO FORMATS
AIFF (.aif, .aiff, .aifc) ALAC WAV (.wav) packed/unpacked FLAC WmA Windows media Audio 9
WAX Windows media audio metafiles ASX Advanced Stream Redirector (.asx) MP3 DSD (.dsf & .dff via USB-B)
SUPPORTED MEDIA SERVERS
Minim Bubble UPnP all UPnP certified media servers
DIMENSIONS & WEIGHT
220mm W | 80mm H | 260mm D 4 Kg
finishes CASE : Brushed Aluminium | Black, Silver or Gold..Blueooth 5.0
Minim Bubble
Τύπος ενισχυτή
Προενισχυτής
Τεχνολογία
Τρανζίστορ (class A/AB)
Gold Note
DS-10
Italy
Κανάλια
Στερεοφωνικός
Είσοδος phono
Ενσωματωμένο DAC
Ναι
NOIZ548661
Αποστολή σε όλη την Ελλάδα
Π
  • Μέλος από το 2023
  • 4 πωλήσεις
